[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no
Mon Jul 13 00:33:05 PDT 2009
in postgis 1.5 trunk from MinGW
When I run make clean in regress-folder I get an error message:
$ make clean
rm -f postgis.sql
make: rm: Command not found
make: *** [clean] Error 127
if I comment away all this in the makefile make clean works :
srcdir=$(shell pwd)
# Put path from pg_config into front of search path
PATH := $(PGSQL_BINDIR):$(PATH)
export PATH
But I still have problems with make check. The cunit-tests work great. then I get:
make -C regress check
make[1]: Entering directory `/c/thesrc/pg15/regress'
sed 's,$libdir/postgis,/../postgis/libpostgis,g' ../postgis/postgis.sql > postgis.sql
./run_test: line 385: psql: command not found
Creating spatial db postgis_reg
./run_test: line 392: createdb: command not found
./run_test: line 393: createlang: command not found
./run_test: line 412: psql: command not found
Something went wrong (no postgis installed in postgis_reg).
For details, check /tmp/pgis_reg_2616/regress_log
make[1]: *** [check] Error 1
make[1]: Leaving directory `/c/thesrc/pg15/regress'
make: *** [check] Error 2
Thanks
Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/fc899739/attachment.html>
