[postgis-devel] 1.4.0 Could it be True
Paragon Corporation
lr at pcorp.us
Mon Jul 13 14:27:24 PDT 2009
Ah never mind about postgis_comments comment -- forgot postgis_comments.sql
was in the 1.3 build as well and this is a diff so could be right.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Greg
Troxel
Sent: Monday, July 13, 2009 5:18 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1.4.0 Could it be True
I am upgrading the pkgsrc entry for postgis and finding the following
differences from 1.3.5. Are these all expected? (PLIST is pkgsrc's list of
the files the package is supposed to install, in this case tuned against
what 1.3.5 does.)
=> Checking file-check results for postgresql82-postgis-1.4.0rc2
ERROR: ************************************************************
ERROR: The following files are in the PLIST but not in /usr/pkg:
ERROR: /usr/pkg/lib/liblwgeom.so
ERROR: /usr/pkg/lib/liblwgeom.so.1
ERROR: /usr/pkg/lib/liblwgeom.so.1.3
ERROR: /usr/pkg/share/doc/postgis/long_xact.xml
ERROR: /usr/pkg/share/postgresql/contrib/lwpostgis.sql
ERROR: /usr/pkg/share/postgresql/contrib/lwpostgis_upgrade.sql
ERROR: The following files are in /usr/pkg but not in the PLIST:
ERROR: /usr/pkg/lib/postgresql/libpostgis-1.4.a
ERROR: /usr/pkg/lib/postgresql/libpostgis-1.4.la
ERROR: /usr/pkg/lib/postgresql/libpostgis-1.4.so
ERROR: /usr/pkg/lib/postgresql/libpostgis-1.4.so.0
ERROR: /usr/pkg/lib/postgresql/libpostgis-1.4.so.0.0.0
ERROR: /usr/pkg/share/doc/postgis/faq.xml
ERROR: /usr/pkg/share/doc/postgis/installation.xml
ERROR: /usr/pkg/share/doc/postgis/introduction.xml
ERROR: /usr/pkg/share/doc/postgis/performance_tips.xml
ERROR: /usr/pkg/share/doc/postgis/reference.xml
ERROR: /usr/pkg/share/doc/postgis/reference_old.xml
ERROR: /usr/pkg/share/doc/postgis/release_notes.xml
ERROR: /usr/pkg/share/doc/postgis/reporting.xml
ERROR: /usr/pkg/share/doc/postgis/template.xml
ERROR: /usr/pkg/share/doc/postgis/using_postgis_app.xml
ERROR: /usr/pkg/share/doc/postgis/using_postgis_dataman.xml
ERROR: /usr/pkg/share/postgresql/contrib/postgis.sql
ERROR: /usr/pkg/share/postgresql/contrib/postgis_upgrade.sql
ERROR: /usr/pkg/share/postgresql/contrib/uninstall_postgis.sql
(I'm also having some minor packaging issues about $libdir substitution in
the loader script, so I can't report on how gmake check does yet.)
