[postgis-devel] 1.4.0 Could it be True
Paragon Corporation lr at pcorp.us
Mon Jul 13 14:26:21 PDT 2009
Yap that looks about right to me (doc became denser and our so/dll, sql
files names changed).  You seem to be missing a postgis_comments.sql though.
Mark or Paul or Kevin are probably more clueful than I am so they should
confirm :)
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Greg
Troxel
Sent: Monday, July 13, 2009 5:18 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1.4.0 Could it be True
I am upgrading the pkgsrc entry for postgis and finding the following
differences from 1.3.5.  Are these all expected?  (PLIST is pkgsrc's list of
the files the package is supposed to install, in this case tuned against
what 1.3.5 does.)
=> Checking file-check results for postgresql82-postgis-1.4.0rc2
ERROR: ************************************************************
ERROR: The following files are in the PLIST but not in /usr/pkg:
ERROR:         /usr/pkg/lib/liblwgeom.so
ERROR:         /usr/pkg/lib/liblwgeom.so.1
ERROR:         /usr/pkg/lib/liblwgeom.so.1.3
ERROR:         /usr/pkg/share/doc/postgis/long_xact.xml
ERROR:         /usr/pkg/share/postgresql/contrib/lwpostgis.sql
ERROR:         /usr/pkg/share/postgresql/contrib/lwpostgis_upgrade.sql
ERROR: The following files are in /usr/pkg but not in the PLIST:
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.a
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.la
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.so
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.so.0
ERROR:         /usr/pkg/lib/postgresql/libpostgis-1.4.so.0.0.0
ERROR:         /usr/pkg/share/doc/postgis/faq.xml
ERROR:         /usr/pkg/share/doc/postgis/installation.xml
ERROR:         /usr/pkg/share/doc/postgis/introduction.xml
ERROR:         /usr/pkg/share/doc/postgis/performance_tips.xml
ERROR:         /usr/pkg/share/doc/postgis/reference.xml
ERROR:         /usr/pkg/share/doc/postgis/reference_old.xml
ERROR:         /usr/pkg/share/doc/postgis/release_notes.xml
ERROR:         /usr/pkg/share/doc/postgis/reporting.xml
ERROR:         /usr/pkg/share/doc/postgis/template.xml
ERROR:         /usr/pkg/share/doc/postgis/using_postgis_app.xml
ERROR:         /usr/pkg/share/doc/postgis/using_postgis_dataman.xml
ERROR:         /usr/pkg/share/postgresql/contrib/postgis.sql
ERROR:         /usr/pkg/share/postgresql/contrib/postgis_upgrade.sql
ERROR:         /usr/pkg/share/postgresql/contrib/uninstall_postgis.sql
(I'm also having some minor packaging issues about $libdir substitution in
the loader script, so I can't report on how gmake check does yet.)
