[postgis-devel] Still no luck getting shp2pgsql-gui to compile under MinGW
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Mon Jul 13 01:26:41 PDT 2009
Hallo  Idon't know, but I followed the error-message. Then I found this in the file shp2pgsql-core.h#ifdef HAVE_ICONV
extern char *encoding; /* iconv encoding name */
#endif
so I guess that HAVE_ICONV gives a not desired answer since the problem according to the error-message is that encoding is not declared. just a guess /Nicklas
2009-07-13 Paragon Corporation wrote:
We get different results from this clean box than my prior attempts, but
>still fails at trying to build the gui.
>Attached is the build log just trying to build the loader.
>Output of our pkg-config --cflags gtk+-2.0 looks like the below
>-mms-bitfields -Ic:/MinGW/include/gtk-2.0 -Ic:/MinGW/lib/gtk-2.0/include
>-Ic:/MinGW/include/atk-1.0 -Ic:/MinGW/include/cairo
>-Ic:/MinGW/include/pango-1.0 -Ic:/MinGW/include/glib-2.0
>-Ic:/MinGW/lib/glib-2.0/include -Ic:/MinGW/include/libpng12
>We had originally tried to install under c:/gtk/opt and can't remember the
>exact errors we got with that. They might have been the same.
>Anyrate maybe someone has some clues. I think on my corrupted box, I was
>able to get further. The shp2pgsql-gui.o was being produced and was
>breaking at building the exe. But then I was fiddling around with the
>makefile so much that one of my fiddles might have made it get that far.
>Thanks,
>Regina and Leo
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/16fb291e/attachment.html>
