[postgis-devel] Still no luck getting shp2pgsql-gui to compileunder MinGW
Paragon Corporation lr at pcorp.us
Mon Jul 13 01:34:41 PDT 2009
Nicklas,
Hmm hadn't bothered looking at that.  We'll take a look at this later.  If
you want to give it a try on your install, we started documenting what we
did here
http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompileWithgui
I was being stupid earlier trying to download and compile all the millions
of dependencies  first time I tried until I realized there was a precompiled
GTK bundle.
Thanks,
Regina
  _____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
nicklas.aven at jordogskog.no
Sent: Monday, July 13, 2009 4:27 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Still no luck getting shp2pgsql-gui to
compileunder MinGW
Hallo
Idon't know, but I followed the error-message. Then I found this in the file
shp2pgsql-core.h
#ifdef HAVE_ICONV
extern char *encoding; /* iconv encoding name */
#endif
so I guess that HAVE_ICONV gives a not desired answer since the problem
according to the error-message is that encoding is not declared.
just a guess
/Nicklas
2009-07-13 Paragon Corporation wrote:
We get different results from this clean box than my prior attempts, but
>still fails at trying to build the gui.
>Attached is the build log just trying to build the loader.
>Output of our pkg-config --cflags gtk+-2.0 looks like the below
>-mms-bitfields -Ic:/MinGW/include/gtk-2.0 -Ic:/MinGW/lib/gtk-2.0/include
>-Ic:/MinGW/include/atk-1.0 -Ic:/MinGW/include/cairo
>-Ic:/MinGW/include/pango-1.0 -Ic:/MinGW/include/glib-2.0
>-Ic:/MinGW/lib/glib-2.0/include -Ic:/MinGW/include/libpng12
>We had originally tried to install under c:/gtk/opt and can't remember the
>exact errors we got with that. They might have been the same.
>Anyrate maybe someone has some clues. I think on my corrupted box, I was
>able to get further. The shp2pgsql-gui.o was being produced and was
>breaking at building the exe. But then I was fiddling around with the
>makefile so much that one of my fiddles might have made it get that far.
>Thanks,
>Regina and Leo
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/61f1a070/attachment.html>
