[postgis-devel] RT_GeoReference problem
Jorge Arévalo jorge.arevalo at gmail.com
Tue Jul 14 13:04:33 PDT 2009
2009/7/14 Jorge Arévalo <jorge.arevalo at gmail.com>:
> On Tue, Jul 14, 2009 at 5:06 PM, Pierre
> Racine<Pierre.Racine at sbf.ulaval.ca> wrote:
>>>I've executed this query:
>>>select ST_GdalGeoTransform(rast) FROM table;
>>>And the result only has 1 value (the first value of the 6-array), Is
>>>it normal?, A bug or am I doing something wrong?
>> You probably have to expand the cell down a bit to see it...
> Yes, good advice. I always expand the cell until the end of the
> window, just in case. But it's not the problem. See the attach
Ok, from command line client doesn't happen... PQAdmin bug?
Best regards
Jorge
