[postgis-devel] RT_GeoReference problem
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Jul 14 15:32:32 PDT 2009
Try to expand down a single cell of the resulting table. See attached...
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Jorge Arévalo
>Sent: 14 juillet 2009 16:05
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] RT_GeoReference problem
>2009/7/14 Jorge Arévalo <jorge.arevalo at gmail.com>:
>> On Tue, Jul 14, 2009 at 5:06 PM, Pierre
>> Racine<Pierre.Racine at sbf.ulaval.ca> wrote:
>>>>I've executed this query:
>>>>select ST_GdalGeoTransform(rast) FROM table;
>>>>And the result only has 1 value (the first value of the 6-array), Is
>>>>it normal?, A bug or am I doing something wrong?
>>> You probably have to expand the cell down a bit to see it...
>> Yes, good advice. I always expand the cell until the end of the
>> window, just in case. But it's not the problem. See the attach
>Ok, from command line client doesn't happen... PQAdmin bug?
>Best regards
>Jorge
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: image/gif
Desc: cellexpand.gif
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090714/7f9436ab/attachment.gif>
