[postgis-devel] problem with makefile in MinGW in trunk
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Jul 17 02:47:41 PDT 2009
nicklas.aven at jordogskog.no wrote:
> I don't know if I understod you right, but I tried to put "echo $(PATH)"
> in different places in Makefile
> The resulting error was:
> make -C regress check
> make[1]: Entering directory `/c/thesrc/pg15/regress'
> Makefile:16: *** target pattern contains no `%'.  Stop.
> make[1]: Leaving directory `/c/thesrc/pg15/regress'
> make: *** [check] Error 2
> /Nicklas
Hmmm how strange. Did you re-run configure to regenerate the new
Makefile after applying the patch?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
