[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Fri Jul 17 03:25:43 PDT 2009
Here it comes/Nicklas
2009-07-17 Mark Cave-Ayland wrote:
nicklas.aven at jordogskog.no wrote:
>> yes, I think I did
>> and now I downloaded the trunk agin,
>> applied the patced
>> and ran:
>> autogen.sh
>> configure --prefix=/c/postgres84
>> --with-pgconfig=/c/postgres84/bin/pg_config
>> -with-geosconfig=/c/postgres84/bin/geos-config --with-projdir=/c/proj4
>> && make && make install
>> and then:
>> make check
>> but I still get the same errors.
>> I don't have proj4 in the postgres-tree as you see, but that shouldn't
>> matter?
>> /Nicklas
>Yeah, that shouldn't affect the PATH at all :( Can you post the
>contents of regress/Makefile?
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/39d3a78e/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/39d3a78e/attachment.ksh>
