[postgis-devel] problem with makefile in MinGW in trunk
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jul 17 03:28:40 PDT 2009
nicklas.aven at jordogskog.no wrote:
> Here it comes
> /Nicklas
Okay - can you make the following change and see what PATH is displayed
when you do a "make check"?
all: test
test check: ../postgis/postgis.sql ../loader/pgsql2shp ../loader/shp2pgsql
sed 's,$$libdir/postgis,$(srcdir)/../postgis/libpostgis,g'
../postgis/postgis.sql > postgis.sql
echo $(PATH)
@USE_VERSION=$(POSTGIS_PGSQL_VERSION) ./run_test $(TESTS)
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
