[postgis-devel] trunk regress fails
Kevin Neufeld
kneufeld at refractions.net
Wed Jul 22 11:13:05 PDT 2009
I don't think this is related to the path problem, but this also happens on the same box.
This is error I get when trying to install postgis in a new install of 8.2.13
postgis=# \i /var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3871: ERROR: cannot cast type text to cstring
LINE 4: CAST('quad_segs='||CAST($3 AS text) as cstring))
psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3881: ERROR: current transaction is aborted, commands
ignored until end of transaction block
psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3887: ERROR: current transaction is aborted, commands
-- Kevin
Kevin Neufeld wrote:
> Does anyone have insight to what is happening here?
> Trunk builds and installs just fine. But when I try to run the
> regression tests, make fails.
> # after make install
> cd regress
> make
> sed
> 's,$libdir/postgis,/var/home/buildbot/workspace/src/regress/../postgis/libpostgis,g'
> ../postgis/postgis.sql > postgis.sql
> ./run_test: line 388: psql: command not found
> Creating spatial db postgis_reg
> ./run_test: line 395: createdb: command not found
> ./run_test: line 396: createlang: command not found
> ./run_test: line 415: psql: command not found
> Something went wrong (no postgis installed in postgis_reg).
> For details, check
> /var/home/buildbot/workspace/regress_results/regress_log
> But, psql IS on the PATH:
> [buildbot at falcon regress]$ echo $PATH
> /usr/local/bin:/bin:/usr/bin:/var/home/buildbot/opt/pgsql/8.2/bin
> [buildbot at falcon regress]$ which psql
> ~/opt/pgsql/8.2/bin/psql
> [buildbot at falcon regress]$ psql -l
> List of databases
> Name | Owner | Encoding
> postgres | buildbot | UTF8
> template0 | buildbot | UTF8
> template1 | buildbot | UTF8
> (3 rows)
> Cheers,
> Kevin
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
