[postgis-devel] trunk regress fails
Paragon Corporation lr at pcorp.us
Wed Jul 22 11:52:51 PDT 2009
Kevin,
What about branches/1.4
I don't think we should be worrying about trunk right now when we are trying
to get 1.4 out the door.
I had tested 1.4 branches on my OpenSUSE 8.2 and it seemed to work fine and
make check fine.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Wednesday, July 22, 2009 2:13 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] trunk regress fails
I don't think this is related to the path problem, but this also happens on
the same box.
This is error I get when trying to install postgis in a new install of
8.2.13
postgis=# \i /var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3871: ERROR:
cannot cast type text to cstring
LINE 4:   CAST('quad_segs='||CAST($3 AS text) as cstring))
psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3881: ERROR:
current transaction is aborted, commands ignored until end of transaction
block
psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3887: ERROR:
block
-- Kevin
Kevin Neufeld wrote:
> Does anyone have insight to what is happening here?
> Trunk builds and installs just fine.  But when I try to run the
> regression tests, make fails.
> # after make install
> cd regress
> make
> sed
's,$libdir/postgis,/var/home/buildbot/workspace/src/regress/../postgis/libpo
stgis,g'
> ../postgis/postgis.sql > postgis.sql
> ./run_test: line 388: psql: command not found Creating spatial db
> postgis_reg
> ./run_test: line 395: createdb: command not found
> ./run_test: line 396: createlang: command not found
> ./run_test: line 415: psql: command not found
>  Something went wrong (no postgis installed in postgis_reg).
>  For details, check
> /var/home/buildbot/workspace/regress_results/regress_log
> But, psql IS on the PATH:
> [buildbot at falcon regress]$ echo $PATH
> /usr/local/bin:/bin:/usr/bin:/var/home/buildbot/opt/pgsql/8.2/bin
> [buildbot at falcon regress]$ which psql
> ~/opt/pgsql/8.2/bin/psql
> [buildbot at falcon regress]$ psql -l
>         List of databases
>    Name    |  Owner   | Encoding
>  postgres  | buildbot | UTF8
>  template0 | buildbot | UTF8
>  template1 | buildbot | UTF8
> (3 rows)
> Cheers,
> Kevin
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
