[postgis-devel] Vote for 1.4 Release
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jul 22 14:18:43 PDT 2009
OS/X (PostGIS 1.4 + PgSQL 8.3) is still good.
Run tests: 42
Failed: 0
P
On Wed, Jul 22, 2009 at 2:15 PM, Paragon Corporation<lr at pcorp.us> wrote:
> Kevin,
> Given that these are the kind of errors we were getting on windows earlier,
> I am a little concerned.
> Paul -- does it still work for you on Mac OSX. I can test my other OpenSUSE
> box, which is running Pg 8.3 I think.
> Like I said, the OpenSUSE I tested this morning was running 8.2.something,
> but I did have to do an sh autogen.sh (I think I got similar errors before I
> did that).
> Looks like you did that though.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
> Neufeld
> Sent: Wednesday, July 22, 2009 5:00 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Vote for 1.4 Release
> K, well, since everyone else can get it working then I must be doing
> something wierd cuz I can't get the regression to actually run. I can get
> PostGIS installed and working just fine ... I just can't get the regression
> suite to run.
> I don't see any issues when using a similar script against the 1.3 branch.
> Attached is a script and results I get when trying to run regression against
> an empty 8.2.13 install. (error occurs in line 326 in log file) pg_config is
> not found.
> If you're convinced it's just me, then I vote +1 as well.
> -- Kevin
> Kevin Neufeld wrote:
>> I'm just running regression now. At first glance, I don't get the
>> same errors as with trunk when running postgis.sql, but I am getting
>> the same make regress errors.
>> Looking a little more into this now.
>> -- Kevin
>> Paragon Corporation wrote:
>>> Good. So we are just waiting for Kevin since Mark has already giving
>>> his blessing.
>>> Paul Ramsey
>>> Sent: Wednesday, July 22, 2009 3:09 PM
>>> Nope, I vote +1, I'd rather have a release out than not. And the
>>> volume of bug reports will help us determine what stupid regression
>>> mistakes we have left in place and whether they are important.
>>> P.
>>> On Wed, Jul 22, 2009 at 12:01 PM, Paragon Corporation<lr at pcorp.us> wrote:
>>>> Paul,
>>>> No. We had pushed that to 1.4.1
>>>> http://trac.osgeo.org/postgis/ticket/222
>>>> This is beginning to sound like a
>>>> "But, we have waited for so long why don't we put the icing on the
>>>> cake and wait for the GUI to compile under windows?"
>>>> If you are thinking that then we should probably have an RC3 and take
>>>> care of the upgrade issue I mentioned here
>>>> http://trac.osgeo.org/postgis/ticket/223
>>>> I'm pretty sure our upgrade script is missing the box3d_extents
>>>> autocasts.
>>>> I also feel we should make the box3d_extent --> box2d CAST explicit
>>>> instead of implicit.
>>>> I believe that is the CAST that is causing me problems when I restore
>>>> a 1.3 db unto a fresh 1.4 db and I question its value since I think
>>>> most of our functions Have casts for box3d. That I haven't tested
>>>> though.
>>>> Thanks,
>>>> Regina
>>>> Paul Ramsey
>>>> Sent: Wednesday, July 22, 2009 1:01 PM
>>>> Does the GUI build?
>>>> On Wed, Jul 22, 2009 at 9:26 AM, Paragon Corporation<lr at pcorp.us> wrote:
>>>>> We have successfully make checked under windows for 8.2,8.3,8.4
>>>>> Can we have a 1.4 release
>>>>> +1
>>>>> Thanks,
>>>>> Regina
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
