[postgis-devel] Vote for 1.4 Release
Paragon Corporation
lr at pcorp.us
Wed Jul 22 14:42:23 PDT 2009
OpenSUSE 11 8.3 polygonize_garray seems to be doing something funky with
with polygons.
I new I should have left well enough alone. Anyrate I'll try blowing out my
svn and redownload.
If you could take a look and see if this looks like anything to be worried
about.
PostgreSQL 8.3.1 on i686-pc-linux-gnu, compiled by GCC gcc (SUSE Linux)
4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]
Postgis 1.4.0SVN - 2009-07-22 21:32:42
GEOS: 3.1.1-CAPI-1.6.0
PROJ: Rel. 4.6.0, 21 Dec 2007
Running tests
loader/Point.............. ok
loader/PointM.............. ok
loader/PointZ.............. ok
loader/MultiPoint.............. ok
loader/MultiPointM.............. ok
loader/MultiPointZ.............. ok
loader/Arc.............. ok
loader/ArcM.............. ok
loader/ArcZ.......... ok
loader/Polygon.............. ok
loader/PolygonM.............. ok
loader/PolygonZ.............. ok
regress. ok
regress_index. ok
regress_index_nulls. ok
lwgeom_regress. ok
regress_lrs. ok
removepoint. ok
setpoint. ok
simplify. ok
snaptogrid. ok
affine. ok
wkt. ok
measures. ok
long_xact. ok
ctors. ok
sql-mm-serialize. ok
sql-mm-circularstring. ok
sql-mm-compoundcurve. ok
sql-mm-curvepoly. ok
sql-mm-general. ok
sql-mm-multicurve. ok
sql-mm-multisurface. ok
geojson. ok
gml. ok
svg. ok
kml. ok
regress_ogc. failed (diff expected obtained:
/tmp/pgis_reg_5900/test_38_diff)
regress_bdpoly. ok
regress_proj. ok
regress_ogc_cover. ok
Run tests: 41
Failed: 1
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, July 22, 2009 5:19 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Vote for 1.4 Release
OS/X (PostGIS 1.4 + PgSQL 8.3) is still good.
Run tests: 42
Failed: 0
P
On Wed, Jul 22, 2009 at 2:15 PM, Paragon Corporation<lr at pcorp.us> wrote:
> Kevin,
> Given that these are the kind of errors we were getting on windows
> earlier, I am a little concerned.
> Paul -- does it still work for you on Mac OSX. I can test my other
> OpenSUSE box, which is running Pg 8.3 I think.
> Like I said, the OpenSUSE I tested this morning was running
> 8.2.something, but I did have to do an sh autogen.sh (I think I got
> similar errors before I did that).
> Looks like you did that though.
> Thanks,
> Regina
> Kevin Neufeld
> Sent: Wednesday, July 22, 2009 5:00 PM
> K, well, since everyone else can get it working then I must be doing
> something wierd cuz I can't get the regression to actually run. I can
> get PostGIS installed and working just fine ... I just can't get the
> regression suite to run.
> I don't see any issues when using a similar script against the 1.3 branch.
> Attached is a script and results I get when trying to run regression
> against an empty 8.2.13 install. (error occurs in line 326 in log
> file) pg_config is not found.
> If you're convinced it's just me, then I vote +1 as well.
> -- Kevin
> Kevin Neufeld wrote:
>> I'm just running regression now. At first glance, I don't get the
>> same errors as with trunk when running postgis.sql, but I am getting
>> the same make regress errors.
>> Looking a little more into this now.
>> -- Kevin
>> Paragon Corporation wrote:
>>> Good. So we are just waiting for Kevin since Mark has already
>>> giving his blessing.
>>> Paul Ramsey
>>> Sent: Wednesday, July 22, 2009 3:09 PM
>>> Nope, I vote +1, I'd rather have a release out than not. And the
>>> volume of bug reports will help us determine what stupid regression
>>> mistakes we have left in place and whether they are important.
>>> P.
>>> On Wed, Jul 22, 2009 at 12:01 PM, Paragon Corporation<lr at pcorp.us>
wrote:
>>>> Paul,
>>>> No. We had pushed that to 1.4.1
>>>> http://trac.osgeo.org/postgis/ticket/222
>>>> This is beginning to sound like a
>>>> "But, we have waited for so long why don't we put the icing on the
>>>> cake and wait for the GUI to compile under windows?"
>>>> If you are thinking that then we should probably have an RC3 and
>>>> take care of the upgrade issue I mentioned here
>>>> http://trac.osgeo.org/postgis/ticket/223
>>>> I'm pretty sure our upgrade script is missing the box3d_extents
>>>> autocasts.
>>>> I also feel we should make the box3d_extent --> box2d CAST explicit
>>>> instead of implicit.
>>>> I believe that is the CAST that is causing me problems when I
>>>> restore a 1.3 db unto a fresh 1.4 db and I question its value
>>>> since I think most of our functions Have casts for box3d. That I
>>>> haven't tested though.
>>>> Thanks,
>>>> Regina
>>>> Paul Ramsey
>>>> Sent: Wednesday, July 22, 2009 1:01 PM
>>>> Does the GUI build?
>>>> On Wed, Jul 22, 2009 at 9:26 AM, Paragon Corporation<lr at pcorp.us>
wrote:
>>>>> We have successfully make checked under windows for 8.2,8.3,8.4
>>>>> Can we have a 1.4 release
>>>>> +1
>>>>> Thanks,
>>>>> Regina
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090722/b70b59d3/attachment.obj>
