[postgis-devel] Re: [PostGIS] #153: gdal2wktraster.py: check for same pixelsize when loading using wildcard
PostGIS trac at osgeo.org
Tue Jun 2 02:30:59 PDT 2009
  Reporter:  pracine    |       Owner:  pracine
      Type:  defect     |      Status:  assigned
  Priority:  medium     |   Milestone:  wktraster 0.1.6
 Component:  wktraster  |     Version:
Resolution:             |    Keywords:  gdal2wktraster
Comment (by mloskot):
 Pierre,
 This report is incomplete. I don't understand what changes you are
 referring to. Has there been broken anything recently or it's a lack of a
 feature? Give exact command you use.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/153#comment:3>
