[postgis-devel] Re: [PostGIS] #153: gdal2wktraster.py: check for same pixelsize when loading using wildcard
PostGIS trac at osgeo.org
Tue Jun 2 11:15:28 PDT 2009
  Reporter:  pracine    |       Owner:  pracine
      Type:  defect     |      Status:  assigned
  Priority:  medium     |   Milestone:  wktraster 0.1.6
 Component:  wktraster  |     Version:
Resolution:             |    Keywords:  gdal2wktraster
Old description:
> It is now possible to load rasters with different pixelsize in the same
> table. Is it desirable? Probably not.
New description:
 table when using the wildcard in gdal2wktraster.py (one raster could have
 a pizelsize of 30m and another one a pixelsize of 15m).
 gdal2wktraster.py should check that pixelsizes from different raster are
 identical or at least warns the user that he is triying to load rasters
 with different pixeltypes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/153#comment:4>
