[postgis-devel] Re: [PostGIS] #190: populate_geometry_columns gives nonstandard use of \' in a string literal
PostGIS trac at osgeo.org
Sun Jun 7 21:45:31 PDT 2009
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  low      |   Milestone:  postgis 1.4.1
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by kneufeld):
 Regina,  Ok.. I'm trying to duplicate the the behaviour you are seeing but
 not having any luck ... if it's an 8.4 thing that would explain it.
 As you suggest, we'll leave this for 1.4.1.
 -- Kevin
Ticket URL: <http://trac.osgeo.org/postgis/ticket/190#comment:6>
