[postgis-devel] Re: [PostGIS] #190: populate_geometry_columns gives nonstandard use of \' in a string literal
trac at osgeo.org
Mon Jun 8 09:45:35 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: postgis 1.4.0
Component: postgis | Version: 1.4
Resolution: | Keywords:
Changes (by robe):
* milestone: postgis 1.4.1 => postgis 1.4.0
Comment:
Okay I brought this up and it is intended new behavior -- notes from Tom
Lane:
from pg bug -- http://archives.postgresql.org/pgsql-bugs/2009-
06/msg00045.php
Kevin if you want I can fix this one since I can test it or you can fix
and I'll verify it works -- simple enough that we might as well do in
1.4.0 - so switching back.
This is an intended change: RAISE format strings are now processed the
same as any other string literal. Personally I'd suggest using '' here
rather than \' --- more standard, more future-proof, etc.
(Hmm, there seems to be nothing about it in the release notes ... not
sure how we overlooked that.)
regards, tom lane
Ticket URL: <http://trac.osgeo.org/postgis/ticket/190#comment:7>
