[postgis-devel] Re: [PostGIS] #144: Hard/soft upgrade need to be tested
trac at osgeo.org
Wed Jun 10 08:44:15 PDT 2009
Reporter: pramsey | Owner: pramsey
Type: task | Status: closed
Priority: high | Milestone: postgis 1.4.0
Component: postgis | Version: 1.4
Resolution: fixed | Keywords:
Changes (by pramsey):
* status: assigned => closed
* resolution: accepted => fixed
Comment:
Hard upgrade tested and updated. Seems to work fine from 1.3 -> 1.4. Soft
upgrade tested and updated. We have some dropped signatures where there
are no new definitions for old functions.
histogram2d_in | $libdir/liblwgeom
st_histogram2d_in | $libdir/liblwgeom
histogram2d_out | $libdir/liblwgeom
st_histogram2d_out | $libdir/liblwgeom
dump | $libdir/liblwgeom
create_histogram2d | $libdir/liblwgeom
st_create_histogram2d | $libdir/liblwgeom
build_histogram2d | $libdir/liblwgeom
st_build_histogram2d | $libdir/liblwgeom
explode_histogram2d | $libdir/liblwgeom
st_explode_histogram2d | $libdir/liblwgeom
estimate_histogram2d | $libdir/liblwgeom
st_estimate_histogram2d | $libdir/liblwgeom
postgis_jts_version | $libdir/liblwgeom
text | $libdir/liblwgeom
st_text | $libdir/liblwgeom
jtsnoop | $libdir/liblwgeom
_st_asgml | $libdir/liblwgeom
I think this is an non-issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/144#comment:3>
