[postgis-devel] RFC3
Paragon Corporation
lr at pcorp.us
Thu Jun 11 03:25:39 PDT 2009
Mark,
I wasn't so much thinking about different versions but more as people who
upgraded from 1.2 to say 1.3 without a dump reload. In those cases some may
be using the st_ and some may be using the non-st version for the operators.
If it was simply an issue of the st_ .. Like I said -- I'm pretty sure a
ALTER FUNCTION RENAME to some other name we haven't used would suffice. I
think Mark the suggestion for names you had would work since those have
never been used.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, June 10, 2009 12:46 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] RFC3
Paul Ramsey wrote:
> *sigh* You're right, the fact that many of the system st_* variants
> that I hate, and want to remove, are underneath operators and types
> makes it impossible to get rid of them cleanly without losing soft
> upgrade. I guess I will just have to move this to 2.0, when
> dump/restore will be mandatory.
> P
For an upgrade between minor versions, I have no problem with manually
altering the catalogues as part of the update script. I think we need to
accept that we may need an upgrades/ directory containing .sql files to
allow upgrading between different versions.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
