[postgis-devel] images/st_buffer* missing ?
Paragon Corporation lr at pcorp.us
Wed Jun 24 07:18:47 PDT 2009
I don't think any pre-generated images are supposed to be in doc/html/images
except possibly in the tar ball.  I think those might have been left over
from before.  I for one did not put any images in that folder for the new
ones I created
since Kevin's doc builder automagically does this on the site.  Those might
be the ones you are noticing are missing.  I suppose we should clean up that
folder at some point so it only has the images that aren't generated.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, June 24, 2009 8:40 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] images/st_buffer* missing ?
strk wrote:
> Forget it, running ./autogen.sh fixed it.
> --strk;
Yeah, the images should be automatically generated from the source.
Actually it looks as if some of pre-generated images are missing from
doc/html/images compared to doc/html/image_src - Kevin, could you verify if
this is supposed to be the case or not?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
