[postgis-devel] images/st_buffer* missing ?
Kevin Neufeld
kneufeld at refractions.net
Wed Jun 24 09:01:02 PDT 2009
Yeah, I think you're seeing the old images from before. Except for the little images like note.gif and such, the images
directory should be empty. We'll have to clean that up and remove all the non-generated images.
I see that whoever build the 1.4Beta forgot to generate the images for the tarball (the old ones are still being used)
... maybe that should be changed for the official 1.4 release.
-- Kevin
Paragon Corporation wrote:
> I don't think any pre-generated images are supposed to be in doc/html/images
> except possibly in the tar ball. I think those might have been left over
> from before. I for one did not put any images in that folder for the new
> ones I created
> since Kevin's doc builder automagically does this on the site. Those might
> be the ones you are noticing are missing. I suppose we should clean up that
> folder at some point so it only has the images that aren't generated.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
> Cave-Ayland
> Sent: Wednesday, June 24, 2009 8:40 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] images/st_buffer* missing ?
> strk wrote:
>> Forget it, running ./autogen.sh fixed it.
>> --strk;
> Yeah, the images should be automatically generated from the source.
> Actually it looks as if some of pre-generated images are missing from
> doc/html/images compared to doc/html/image_src - Kevin, could you verify if
> this is supposed to be the case or not?
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
> Corporation plc - control through freedom http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
