[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
PostGIS trac at osgeo.org
Mon Jun 29 07:31:21 PDT 2009
  Reporter:  dfuhriman  |       Owner:  robe
      Type:  defect     |      Status:  assigned
  Priority:  medium     |   Milestone:  postgis 1.3.7
 Component:  postgis    |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 Mark just to verify I guess you didn't touch the make line at all since
 you are waiting to make sure ST_Union is perfect before copying the same
 logic?
 SELECt ST_MakeLine(Array[null,null, null, null]);
 still crashes on my 8.4 install.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:16>
