[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
trac at osgeo.org
Tue Jun 30 01:33:03 PDT 2009
Reporter: dfuhriman | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
More update. This does not return same result as my old install.
I tested on my windows 1.3.6 build against 8.3.7 and this
SELECT ST_AsText(ST_Union(the_geom))
FROM (SELECT CASE WHEN i%4 = 0 THEN ST_SetSRID(ST_Point(i,j),4326) ELSE
NULL END As the_geom
FROM generate_series(1,20) As i CROSS JOIN generate_series(-30, 40) As j)
As foo;
Returns: As I would expect -- a MULTIPOINT
-- On my PostgreSQL 8.4 Windows 1.4b install strangely it also returns
that mixed SRID funky error. But to make sure I was testing a newer
version I did retest this on my 1.4b
SELECT ST_Union(the_geom) FROM (VALUES (ST_GeomFromText('POINT(1 2)') ),
(null), (null) ) As foo(the_geom)
and it returns the geometry type 0 not defined thing
but on your new patch (my OpenSUSE patched - it works)
So the fact that the below is inconsistent between 1.3 and 1.4 means sadly
:( more work to be done here.
As foo;
I'm sure I have made this behave irradically on a 1.3 beofre. Perhaps it
was a 64-bit and I don't have a non-production one to test with.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:23>
