[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
trac at osgeo.org
Tue Jun 30 05:37:48 PDT 2009
Reporter: dfuhriman | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Mark,
Sorry to do this to you again. Just when I thought I was out of ideas on
how to trip you up. The above test works fine now.
I have this dataset I know is bad -- its got invalid geometries. Never
been able to union it -- because it always throws topological errors.
In the 1.4b1 build -- for this
SELECT ST_NumGeometries(ST_Union(the_geom))
from neighborhoods;
I get this thoughtful message
NOTICE: TopologyException: found non-noded intersection between 779062
2.92623e+06, 779069 2.92622e+06 and 779072 2.92622e+06, 778970 2.92625e+06
779068 2.92622e+06
ERROR: Union returned a NULL geometry.
********** Error **********
SQL state: XX000
In your current incarnation -- I just get a null back - no explanation
what so ever. It does work of course in both cases if I exclude the
invalid geometries.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:27>
