[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
trac at osgeo.org
Tue Jun 30 06:53:03 PDT 2009
Reporter: dfuhriman | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
Replying to [comment:28 robe]:
> Mark,
> Sorry I misspoke a little bit. I think it may be fine. I do get a
notice but no error. So I get a notice that says
> NOTICE: TopologyException: found non-noded intersection between 779062
2.92623e+06, 779069 2.92622e+06 and 779072 2.92622e+06, 778970 2.92625e+06
779068 2.92622e+06
> (but forgot to switch to the notice tab of PgAdmin to see)
> In the old model on 1.3 I would get a notice saying GEOS topological
exception accompanied with a ERROR: GEOS union() threw an error!
Hmmm. Well this bit I didn't change in the patch attached here...
> In the PostGIS 1.4b1 I would get an error saying returned null geometry
in addition to the topological notice.
> In this patch I just get the topological notice -- no error which hmm in
some cases I like better.
> So I guess I'm not sure what to consider this. It is slightly different
behavior, but perhaps acceptable.
Yeah I had to change this. The old code assumed that ST_Union() returning
NULL was an error, but of course NULL is actually valid return value when
you perform f(NULL) on a set of NULLs...
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:29>
