[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
trac at osgeo.org
Tue Jun 30 14:31:26 PDT 2009
Reporter: dfuhriman | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
Okay - here is a reasonably complete patch which should fix the following
aggregates/functions in terms of NULLs:
ST_Union() / ST_Union( array )
ST_Collect() / ST_Collect ( array )
ST_Polygonize() / ST_Polygonize ( array )
ST_MakeLine() / ST_MakeLine ( array )
Regina/Paul, can you test at your end? I've done some quick tests here,
however I'm not 100% confident enough to commit yet. Basically inputs with
no nulls should match that from 1.3, while inputs with varying
combinations of NULLs (and on a table with a column containing NULLs as
this is a different code path) should just now return NULL.
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:32>
