[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
trac at osgeo.org
Tue Jun 30 14:57:36 PDT 2009
Reporter: dfuhriman | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Mr,
I assume I misread you here. So we are saying something like
ST_Agg(allnulls) should return NULL now rather than crash, but
ST_Agg(somenulls) may or may not return NULL? e.g. in case of makeline a
NULL, point would return null, but in the case of union Null, Point would
return the point?
Well I assume that is the behavior people expect. Just want to verify
since your comment suggested you would return NULL if any combination of
NULLS is input.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:33>
