[postgis-devel] Issue 121 in postgis: update tiger_geocoder to run in PostgreSQL 8.3 (patch attached)
codesite-noreply at google.com
Sun Mar 1 17:03:16 PST 2009
Status: New
Owner: ----
New issue 121 by cdwinslow: update tiger_geocoder to run in PostgreSQL 8.3
(patch attached)
http://code.google.com/p/postgis/issues/detail?id=121
I was playing with the TIGER geocoder this weekend and had to make a few
changes for it to work in PostgreSQL 8.3. If I remember correctly they are
all type casts or variable declaration changes to avoid comparing text to
numeric values.
tiger_geocoder-pg-8.3.patch 9.6 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
