[postgis-devel] configure error while buildingWKTRaster onUbuntu8.10
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Mar 4 08:50:07 PST 2009
Mateusz Loskot wrote:
> You're getting this error for PostGIS because of the same reason it occurred for WKTRaster - this is lack of libtoolize'ation of the sources. The libtoolize is usually called in autogen.sh script.
> I have no idea why PostGIS' autogen.sh does not call libtoolize. The PostGIS autotools rely on libtool,
> so  it should. Autotools best practice does recommend it:
> "A typical bootstrap might also run libtoolize or autoheader"
> http://sourceware.org/autobook/autobook/autobook_43.html
Yeah, I think this could be my fault - I suspect it works here because I
have the libtool development packages installed on my machine. If it
works, feel free to add it into autogen.sh on trunk.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
