[postgis-devel] configure error whilebuildingWKTRaster onUbuntu8.10
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Wed Mar 4 09:01:48 PST 2009
Mark Cave-Ayland wrote:
> Mateusz Loskot wrote:
> > You're getting this error for PostGIS because of the same reason it
> occurred for WKTRaster - this is lack of libtoolize'ation of the
> sources. The libtoolize is usually called in autogen.sh script.
> > I have no idea why PostGIS' autogen.sh does not call libtoolize. The
> PostGIS autotools rely on libtool,
> > so  it should. Autotools best practice does recommend it:
> > "A typical bootstrap might also run libtoolize or autoheader"
> > http://sourceware.org/autobook/autobook/autobook_43.html
> Yeah, I think this could be my fault - I suspect it works here because
> I
> have the libtool development packages installed on my machine. If it
> works, feel free to add it into autogen.sh on trunk.
It may be my fault to expect that everyone who is going to build stuff
from sources grabbed directly form SVN/CVS must have install all development
packages.
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
