[postgis-devel] Issue 121 in postgis: update tiger_geocoder to run in PostgreSQL 8.3 (patch attached)
codesite-noreply at google.com
Mon Mar 9 07:16:31 PDT 2009
Comment #4 on issue 121 by mark.cav... at siriusit.co.uk: update
http://code.google.com/p/postgis/issues/detail?id=121
This version looks much better. I am still confused by the presence of some
of the
casts, as text <> varchar should just work fine, and some of the ::integer
additions
shouldn't be required if the variable is already defined in PLPGSQL as type
integer.
Regina will be able to comment further though.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
