[postgis-devel] Issue 121 in postgis: update tiger_geocoder to run in PostgreSQL 8.3 (patch attached)
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 23:40:16 PDT 2009
Comment #5 on issue 121 by robe.... at cityofboston.gov: update tiger_geocoder
http://code.google.com/p/postgis/issues/detail?id=121
CD -- yes this does look better.  Regarding Mark's comment, the only
redundancy I see
is the below.  That change you made seems unnecessary.
geocode_address_zip.sql -- line 15 don't think is necessary since your
tempInt is
already an integer
ideally I would have rather changed the lookup tables to match the datatype
of the
census tables, but maybe we can consider that for a second pass.  I think
this is
better than what we have already so maybe we can accept and revisit later.
Am I correct in saying this uses the old proprietary tiger format and
doesn't use the
new census 2007/2008 shapefile structure, or is the documentation just out
of date?
Looking at the table structurs loooks like the old format. In which case
this needs a
lot of rework anyway.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
