[postgis-devel] Issue 121 in postgis: update tiger_geocoder to run in PostgreSQL 8.3 (patch attached)
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 11:14:45 PDT 2009
Comment #6 on issue 121 by cdwinslow: update tiger_geocoder to run in
http://code.google.com/p/postgis/issues/detail?id=121
in reply to comment 5:
agree, line 15 is redundant
agree, it would be nicer to fix up the tables, but I've just been looking
at this in
my spare time.  Also...
yes, the geocoder currently works against just the TIGER data from 2006, so
redoing
the tables without updating them to use more current data formats seems a
bit of a
time-waste.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
