[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DBbackendwith large geometries.
Courtin Olivier olivier.courtin at camptocamp.com
Mon Mar 9 14:09:59 PDT 2009
On Mar 9, 2009, at 5:00 PM, Obe, Regina wrote:
Regina,
> I was using OpenSUSE 11 with GEOS 3.1, but I presume the geos
> doesn't matter for svg.
Indeed, no GEOS operation at all,
> I'll double-check to make sure I did install and so forth -- could
> be something wrong with my install.  I'll also try on another pc
> tomorrow.
Ok, let will see...
on my own:
  POSTGIS="1.4.0SVN" GEOS="3.0.2-CAPI-1.4.2" PROJ="Rel. 4.6.1, 21
August 2008" USE_STATS
  Linux Slackware 12.1
  postgis r 3819
  => Ok on the whole garden test
POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS
Mac Os.X 10.5
postgis r 3817
Olivier
