[postgis-devel] Issue 119 in postgis: ST_AsSVG crashedDBbackendwith large geometries.
Obe, Regina robe.dnd at cityofboston.gov
Mon Mar 9 14:17:08 PDT 2009
That is weird.  Well I destroy my source and rebuild from scratch.  I suppose I could have some junk lying in there from before
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Courtin Olivier
Sent: Mon 3/9/2009 5:09 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Issue 119 in postgis: ST_AsSVG crashedDBbackendwith large geometries.
On Mar 9, 2009, at 5:00 PM, Obe, Regina wrote:
Regina,
> I was using OpenSUSE 11 with GEOS 3.1, but I presume the geos
> doesn't matter for svg.
Indeed, no GEOS operation at all,
> I'll double-check to make sure I did install and so forth -- could
> be something wrong with my install.  I'll also try on another pc
> tomorrow.
Ok, let will see...
on my own:
  POSTGIS="1.4.0SVN" GEOS="3.0.2-CAPI-1.4.2" PROJ="Rel. 4.6.1, 21
August 2008" USE_STATS
  Linux Slackware 12.1
  postgis r 3819
  => Ok on the whole garden test
POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS
Mac Os.X 10.5
postgis r 3817
Olivier
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090309/d09dc0ec/attachment.html>
