[postgis-devel] Remove PDF from Hudson build?
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Mar 10 07:20:08 PDT 2009
Hi Kevin/Regina,
Would it be possible to change the Hudson build so that instead of
building the PDF version of the documentation for each commit, we have a
separate cron job that independently runs once a day?
The reason I ask is that it currently takes nearly 10 mins for each
build which is a real pain when trying to check documentation changes...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
