[postgis-devel] Issue 133 in postgis: Run astyle on full code base
codesite-noreply at google.com
Tue Mar 10 07:18:02 PDT 2009
Status: Accepted
Owner: pwramsey3
Labels: Milestone-1.4
New issue 133 by pwramsey3: Run astyle on full code base
http://code.google.com/p/postgis/issues/detail?id=133
What steps will reproduce the problem?
astyle
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
