[postgis-devel] Issue 132 in postgis: Make check should run CUnit
codesite-noreply at google.com
Tue Mar 10 12:32:14 PDT 2009
Updates:
Status: Fixed
Comment #1 on issue 132 by mark.cav... at siriusit.co.uk: Make check should
run CUnit
http://code.google.com/p/postgis/issues/detail?id=132
Change applied to SVN trunk.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
