[postgis-devel] Remove PDF from Hudson build?
Obe, Regina
robe.dnd at cityofboston.gov
Tue Mar 10 07:26:25 PDT 2009
Also if we are going to be integrating Doxygen doc builds, we can have
that happen at the same time as the PDF.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Tuesday, March 10, 2009 10:20 AM
To: PostGIS Development Discussion
Subject: [postgis-devel] Remove PDF from Hudson build?
Hi Kevin/Regina,
Would it be possible to change the Hudson build so that instead of
building the PDF version of the documentation for each commit, we have a
separate cron job that independently runs once a day?
The reason I ask is that it currently takes nearly 10 mins for each
build which is a real pain when trying to check documentation changes...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
