[postgis-devel] Remove PDF from Hudson build?
Kevin Neufeld kneufeld at refractions.net
Tue Mar 10 08:31:00 PDT 2009
Sure, no problem.  That would mean though that the pdf included in the tarball wouldn't exactly match the html version,
but that's not a big deal.
-- Kevin
Obe, Regina wrote:
> Also if we are going to be integrating Doxygen doc builds, we can have
> that happen at the same time as the PDF.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
> Cave-Ayland
> Sent: Tuesday, March 10, 2009 10:20 AM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] Remove PDF from Hudson build?
> Hi Kevin/Regina,
> Would it be possible to change the Hudson build so that instead of
> building the PDF version of the documentation for each commit, we have a
> separate cron job that independently runs once a day?
> The reason I ask is that it currently takes nearly 10 mins for each
> build which is a real pain when trying to check documentation changes...
> ATB,
> Mark.
