[postgis-devel] Issue 121 in postgis: update tiger_geocoder to run in PostgreSQL 8.3 (patch attached)
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 12:45:19 PDT 2009
Comment #8 on issue 121 by mark.cav... at siriusit.co.uk: update
http://code.google.com/p/postgis/issues/detail?id=121
No, that works for me as long as it still works on older PostgreSQL
versions.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
