[postgis-devel] Issue 121 in postgis: update tiger_geocoder to run in PostgreSQL 8.3 (patch attached)
codesite-noreply at google.com codesite-noreply at google.com
Thu Mar 12 15:32:11 PDT 2009
Updates:
	Status: Testing
Comment #9 on issue 121 by robe.... at cityofboston.gov: update tiger_geocoder
http://code.google.com/p/postgis/issues/detail?id=121
Applied to trunk and 1.3 minus line 15.  I couldn't really test since I
don't have
all the tables, but can't see how any of these changes would break 8.2 and
below.
And quick checks on 8.2 with jury rigged examples seem to work fine.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
