[postgis-devel] Issue 136 in postgis: Remove deprecated definitions from postgis.sql
codesite-noreply at google.com
Mon Mar 16 08:23:38 PDT 2009
Comment #2 on issue 136 by pwramsey3: Remove deprecated definitions from
postgis.sql
http://code.google.com/p/postgis/issues/detail?id=136
Frank asked me the reasonably question "why are you going to do that"? And
my answer was at best lame. I just
don't like them. But they aren't really a maintenance issue (they just sit
there), or even a documentation issue
(they aren't documented anymore).
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
