[postgis-devel] Issue 136 in postgis: Remove deprecated definitions from postgis.sql
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 16 08:31:39 PDT 2009
Comment #3 on issue 136 by mloskot: Remove deprecated definitions from
postgis.sql
http://code.google.com/p/postgis/issues/detail?id=136
Understood. Thanks for the explanation and sorry I haven't asked on the
postgis-devel
list first.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
