[postgis-devel] Issue 140 in postgis: Patch for geometry_column without S at the end typo
codesite-noreply at google.com codesite-noreply at google.com
Thu Mar 19 16:43:51 PDT 2009
Status: New
Owner: ----
New issue 140 by mloskot: Patch for geometry_column without S at the end
typo
http://code.google.com/p/postgis/issues/detail?id=140
This is a small patch fixing geometry_column vs geometry_columns typo in
several places.
	postgis-r3904-geometry_columns-name-fix.patch  3.3 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
