[postgis-devel] Issue 140 in postgis: Patch for geometry_column without S at the end typo
codesite-noreply at google.com codesite-noreply at google.com
Thu Mar 19 21:49:56 PDT 2009
Updates:
	Status: Fixed
	Owner: ke... at refractions.net
	Labels: Type-Patch Milestone-1.4 Priority-Low Component-Docs
Comment #1 on issue 140 by ke... at refractions.net: Patch for geometry_column
http://code.google.com/p/postgis/issues/detail?id=140
Patch applied.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
