[postgis-devel] Issue 63 in postgis: ST_Max_Distance is not yet implemented?
codesite-noreply at google.com
Thu Mar 19 22:39:03 PDT 2009
Updates:
Labels: Milestone-1.4.X
Comment #1 on issue 63 by robe.... at cityofboston.gov: ST_Max_Distance is not
yet implemented?
http://code.google.com/p/postgis/issues/detail?id=63
Someone needs to look at Nicklas patch he attached in issue 137 for max
distance to
see how far off he is from a working solution. Would be nice to see this
working in
1.4.1 and possibily 1.3.7.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
