[postgis-devel] Issue 63 in postgis: ST_Max_Distance is not yet implemented?
codesite-noreply at google.com
Mon Mar 23 14:37:28 PDT 2009
Comment #2 on issue 63 by post... at jordogskog.no: ST_Max_Distance is not yet
implemented?
http://code.google.com/p/postgis/issues/detail?id=63
I have made a new try on st_maxdistance and now I think it is working as I
want. The
last try was very bad. There is a new patch in issue 137
/Nicklas Avén
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
