[postgis-devel] Issue 141 in postgis: AsGML multipoint issue on MacOS X
codesite-noreply at google.com
Fri Mar 20 04:49:46 PDT 2009
Comment #1 on issue 141 by mark.cav... at siriusit.co.uk: AsGML multipoint
issue on MacOS X
http://code.google.com/p/postgis/issues/detail?id=141
Hi Olivier,
I wonder if this is related to the AsSVG() bug? Incidentally, have you
tried enabling
memory checking on your PostgreSQL instance? It makes things run slowly,
but enables
you to track things like this.
What you need to do is build PostgreSQL from source like this:
./configure --enable-debug --enable-cassert
Perhaps this will help point out where the bug lies?
HTH,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
